Hello Guest it is March 29, 2024, 03:25:47 AM
Author Topic: Application Watchdog Triggered Error  (Read 11418 times)
« on: February 10, 2018, 01:18:11 PM »
Hello,
I am using Mach3 with a CNC Router Parts machine. The machine was running along smoothly and then stopped suddenly in the middle of the job. The axes can be jogged and the DRO values change, but the motors do not move. Further, upon restarting Mach3 we get an error: "Application Watchdog Triggered."
Any ideas?
Re: Application Watchdog Triggered Error
« Reply #1 on: February 10, 2018, 06:14:24 PM »
You can turn off Watchdogs in General Config.
See if that helps.
« Reply #2 on: April 17, 2018, 03:20:16 PM »
Any luck on the 'Application Watchdog Triggered' error? I'm getting the same message and I'm having random e-stops that need the controller power cycled to reset.
« Reply #3 on: April 17, 2018, 07:27:43 PM »
as ger21 says, turn the  watchdog timer off on the Gen Config page.
« Reply #4 on: April 18, 2018, 12:01:05 AM »
I've tried turning off the watchdog option and it doesn't seem to help. I still get the same error message on start up and random e-stops.
« Reply #5 on: April 18, 2018, 12:21:56 AM »
try opening Mach3 as normal and have a look at the check box for the Watchdog Timer. Is it checked?
Did you leave it like that last time or has it ignored your previous setting.
I suspect that either Mach is not recording the change in your profile or when you fire up Mach its selecting a different
profile to that you intended.
« Reply #6 on: April 18, 2018, 09:35:47 PM »
Even if that were the case, it would only be suppressing the issue and not resolving it. With the watchdogs off, I get an issue with the PWM signal that maxes out the router for some reason.
« Reply #7 on: April 18, 2018, 09:53:18 PM »
None of these are normal problems.
Are you using a parallel port, or motion controller?
If parallel port, run Drivertest.exe, and post the results.
What version of Mach3? Do you have a legitimate license?
« Reply #8 on: April 18, 2018, 09:55:46 PM »
Warp9 ESS with a Gecko g540... Mach3 R3.043.062 with a legit license
« Reply #9 on: April 18, 2018, 10:00:27 PM »
Contact Warp9.
You shouldn't be seeing any watchdog errors with an ESS.
