Hello
Guest
it is
April 24, 2024, 06:31:30 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
PoKeys
(Moderator:
NeoTO
57U, Mach 3 - A Axis, How?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: 57U, Mach 3 - A Axis, How? (Read 2793 times)
Chaz
48
on:
February 10, 2018, 11:14:00 AM »
The 57U shows connections for X Y and Z channels. I use X and Z for the lathe, the spare channel is Y. Is there a way to tell Pokeys / Mach 3 that this is A instead for a lathe turret?
NeoTO
504
Re: 57U, Mach 3 - A Axis, How?
Reply #1 on:
February 11, 2018, 01:33:11 AM »
Unfortunately, the Mach3 plugin for PoKeys does not support axis remapping.
The best way is to use the external pulse generator (e.g.
https://www.poscope.com/product/poextbusoc16cnc/
), which features the support for all 6 axes (at 125 kHz instead of 25 kHz of built-in).
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Chaz
48
Reply #2 on:
February 11, 2018, 01:52:38 AM »
Thanks, received confirmation too from your support team. Pity.
Chaz
48
Reply #3 on:
February 11, 2018, 01:59:14 AM »
Just looked at the board and the manual. How does it connect to the 57U?
NeoTO
504
Reply #4 on:
February 11, 2018, 04:31:16 AM »
See page 5 of the manual.
Power supply and 4 signal pins must be connected as stated in the table.
www.poscope.com
Print
Pages:
1
Go Up
« previous
next »
