I can fire plasma and manually jog, THC runs great. But when I run gcdoe, it dives into material
Yes! 160 ish seems about right.
Quote from: LexMotorsports on February 15, 2018, 01:17:25 PMI can fire plasma and manually jog, THC runs great. But when I run gcdoe, it dives into material can you pls post your GCode , maybe something is wrong there.
Quote from: LexMotorsports on February 15, 2018, 01:34:55 PMYes! 160 ish seems about right. That was the voltage displayed while doing a straight cut with the THC turned off in Mach3 over a reasonable distance like 200-300mm??
