Hello Guest it is April 18, 2024, 07:54:28 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 36180 times)
Offline TPS
  •  2,505 2,505
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #40 on: February 14, 2018, 09:28:04 AM »
ok just to confirm wiring:
power supply V+ -> G540 terminal 11
power supply GND -> G540 terminal 12
power supply GND -> Proma terminal COM
Proma terminal UP -> G540 terminal 1
Proma terminal DWN -> G540 terminal 2
Proma terminal ARC -> G540 terminal 3
Mach3 Config -> Ports & Pins -> Inputs
THC ON       - Enabled checked - Port 1 Pin 12
THC UP       - Enabled checked - Port 1 Pin 10
THC DOWN - Enabled checked - Port 1 Pin 11
Mach3 1024 Screen set -> diagostics -right hand side about middle
there are three LED's Torch ON , Torch UP , Torch Down
put just for test a wire from
now Torch Up LED should be on.
« Reply #41 on: February 14, 2018, 10:36:27 AM »
My g540 pin 12 goes to my power supply V-. It has always been wired like this.
Offline Davek0974
  •  2,606 2,606
« Reply #42 on: February 14, 2018, 10:41:41 AM »
That is correct, 0v, GND, -v are generally the same thing.
« Reply #43 on: February 14, 2018, 10:47:02 AM »
So my settings in Mach are correct, and I have active lows checked
« Reply #44 on: February 14, 2018, 11:39:41 AM »
Everything seems to be hooked up correctly and I’m using my proma right now just to test voltage from the arc and the proma is getting a bad arc reading or something it keeps cutting in and out
Offline TPS
  •  2,505 2,505
« Reply #45 on: February 14, 2018, 12:29:29 PM »
and what are the THC up and down LED show in diagnostic screen ?
« Reply #46 on: February 14, 2018, 12:44:06 PM »
When I put my proma in test mode it shows arc on and up on proma and in diagnostic it shows torch up, torch on, no movement from torch though. When I run a gcode, it starts, moves to position, fires the plasma and doesn’t move, just continues to blast.
Offline TPS
  •  2,505 2,505
« Reply #47 on: February 14, 2018, 01:54:09 PM »
what are your Settings in
Config -> Ports&Pins - Mill Options -> THC Options ?
« Reply #48 on: February 14, 2018, 02:05:41 PM »
Advanced compensation analysis is checked, allow THC UP/DOWN control is checked
Offline TPS
  •  2,505 2,505
« Reply #49 on: February 14, 2018, 02:15:26 PM »
if you go to Settings Screen, what does the Enable THC Tog. Led ?
