Hello Guest it is April 25, 2024, 01:07:55 AM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 36349 times)
Offline TPS
  •  2,505 2,505
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #210 on: March 01, 2018, 11:40:01 AM »
what is your thc Speed Setting?
don't be surprised about my Setting, i am in metric
Offline Davek0974
  •  2,606 2,606
« Reply #211 on: March 01, 2018, 11:46:01 AM »
Ok, thats possible - try making up some simple code to rapid (G0) the Z axis from Z0 to Z2 (or whatever travel you have, run it maybe 10 times starting from Z0 at a known position and at the end go to Z0 - is the axis in exactly the same position it was at the start???
If you are losing steps it could well be this, plus, when running THC you need to know that the normal acceleration curve is not used, THC moves on Z are more like BANG-BANG-BANG really fast moves are needed here or by the time the Z has moved the torch is elsewhere :)
I think there its a setting called THC-Rate - its a % of speed, try going low and working up, however i cant remember if this is a generic Mach3 setting or one specific to my screen set/THC system.
Test for lost steps first
EDIT
just saw TPS' reply - thats the box i mentioned.
« Reply #212 on: March 01, 2018, 12:32:06 PM »
15
« Reply #213 on: March 01, 2018, 12:38:43 PM »
EDIT
I ran a code
G0 z1
G0 z0
G0 z 1.5
G0 z0
G0 z 1.3
G0 z0
Ect.. maybe 25 times over and over. Z Axis landed in same position every time.
I will mess with my setting on Z axis tuning,
Offline TPS
  •  2,505 2,505
« Reply #214 on: March 01, 2018, 01:02:56 PM »
if you have still your buttons connected to THC up/dn you can also Play a Little bit with the THC speed
Offline Davek0974
  •  2,606 2,606
« Reply #215 on: March 01, 2018, 01:30:08 PM »
Yes as TPS says above, set your Z zero at a known position, then using the buttons move the Z up and down really violently, sharp changes are what is needed, up-down-up-down then go back to Z0 and see if it returned to where you set it.
If not then lower the THC speed a bit and try again.
« Reply #216 on: March 01, 2018, 02:03:31 PM »
Okay, so I’m at This point trying to get my Z axis to travel at its maximum speed before it makes an error?
Offline Davek0974
  •  2,606 2,606
« Reply #217 on: March 01, 2018, 02:10:22 PM »
Well, really we are trying to find out if THC moves (which are different to normal moves) are causing your Z axis to lose steps.
Maximum speed is not relevant yet, just trying to fix your odd Z issues.
« Reply #218 on: March 01, 2018, 04:07:56 PM »
Ever since I adjusted my Z axis motor to run at 15:15, it’s running perfect. I’ve been cutting some 1/4” , 14GA, and 10GA mild steel and it’s awsosme
Offline Davek0974
  •  2,606 2,606
« Reply #219 on: March 01, 2018, 04:12:36 PM »
Sounds good, if it works, go with it :)
