Hello
Guest
it is
April 25, 2024, 01:24:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
Go Down
Author
Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA (Read 36350 times)
Davek0974
2,606
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
Reply #160 on:
February 27, 2018, 04:48:10 PM »
Pierce height should be in the g-code IIRC
Logged
LexMotorsports
133
Reply #161 on:
February 27, 2018, 04:53:46 PM »
MACH is applying random numbers to my Z offset. I don’t know what is going on
Logged
LexMotorsports
133
Reply #162 on:
February 27, 2018, 04:57:12 PM »
The probe isn’t operating correctly anymore, it’s not raising Z to go to pierce height after probing, it’s driving down into the material.
Logged
TPS
2,505
Reply #163 on:
February 27, 2018, 05:36:18 PM »
ok let's get back to the Basics,
open up vb scirper window
copy this code:
pierceHeight = 0.5 'enter here a value for wanted pierceheiht
code "F30"
code "G31 Z-1"
While Ismoving()
Wend
code "G00 Z" & GetVar(2002) 'go back to the probepoint
While Ismoving()
Wend
code "G91 Z-" & pierceHeight
While Ismoving()
Wend
code "G92 Z0"
While Ismoving()
Wend
Code "G90"
and use the ||> green buton to se what's goinng on
Logged
LexMotorsports
133
Reply #164 on:
February 27, 2018, 06:11:48 PM »
It probes good, then dives at g91. I changed 2002 to 0, then re ran, it got all the way passed g91 z- (at this point it was back at Z 0) then it dove .5” down instead of rising .5” up
Logged
TPS
2,505
Reply #165 on:
February 28, 2018, 01:59:14 AM »
sorry should be
code "G91 Z" & pierceHeight
Logged
LexMotorsports
133
Reply #166 on:
February 28, 2018, 11:22:19 AM »
That fixed the probing issue, still having the same issue with the THC.
Logged
TPS
2,505
Reply #167 on:
February 28, 2018, 11:46:25 AM »
is Torch DN in dignosic Screen defenitiv off?
Logged
LexMotorsports
133
Reply #168 on:
February 28, 2018, 11:47:15 AM »
Really interesting, on my second pierce, when it goes to probe it changed my cutting speed From 130 ipm to 30 ipm.?
Logged
LexMotorsports
133
Reply #169 on:
February 28, 2018, 11:48:32 AM »
Quote from: TPS on February 28, 2018, 11:46:25 AM
I don’t understand.. sorry
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
Go Up
« previous
next »
