Hello Guest it is April 18, 2024, 11:39:07 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 36187 times)
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #110 on: February 15, 2018, 03:53:10 PM »
How can I check that? It never has before..
« Reply #111 on: February 15, 2018, 04:02:36 PM »
I put my THC min on 0. Max is 2. I got the THC running with GCODE great. I cut 2 things, but next problem. When running, if the THC measures voltage too far, and makes moves to lower Z, it will go below the 0 THC MIN setting I set. It will finish that cut perfect, regardless that it’s below my THC MIN setting. Next pierce it continues and then drives itself into material.
« Reply #112 on: February 15, 2018, 04:04:36 PM »
Then, I set my THC MIN lower, like at -.5. Go to run again, it cuts first pierce awesome, goes to do second and drives into material, I’m guessing it’s trying to get to that THC MIN setting?
Offline TPS
  •  2,505 2,505
« Reply #113 on: February 16, 2018, 02:31:24 AM »
here:
http://www.machsupport.com/forum/index.php/topic,35183.0.html
i found a thread, witch sounds like the same Problem.
i have read the proma Manual again, i am a Little bit stuck
at this:
"H - U" (High Voltage) - value of the off load voltage detection
in the plasma cutter - used to detect the main (cutting) arc: 50-
300V by default: 200V
Parameter.My question is what does Proma if cutting voltage is below this Parameter ?
for my understanding this Parameter should be below cutting voltage, but i don't really know.
on the Plasma Programm run Screen is a dro called Curr:
this should be zeroed after each M3 call (Torch ON) ?
what does the DOWN LED on Proma in the Situation when the torch goes into material ?
sorry that can't provide the real solution.
Thomas
Offline Davek0974
  •  2,606 2,606
« Reply #114 on: February 16, 2018, 03:36:49 AM »
To find the off-load voltage or open-circuit voltage, just fire the torch into air - this only works if not is a pilot-arc or blowback-arc torch though, and do not do it for too long as it will melt the torch tip.
« Reply #115 on: February 16, 2018, 11:49:30 AM »
I think my PROMA may be bad.. I’m only getting ARC OK signal on the PROMA itself every once in a while and it’s  very inconsistent
Offline TPS
  •  2,505 2,505
« Reply #116 on: February 16, 2018, 12:20:47 PM »
have you tryed this
H - U" (High Voltage) Parameter ?
« Reply #117 on: February 16, 2018, 12:29:42 PM »
HI at do I change it to? Whenever I try a dry fire test in the air to get the correct voltage, it shoots 180-190 v
Offline Davek0974
  •  2,606 2,606
« Reply #118 on: February 16, 2018, 02:07:05 PM »
All you need to discover is the voltage when NOT cutting and the voltage ranges when it IS cutting - set the H-U setting to be higher than the voltages when cutting as it needs to see the change from piercing to cutting.
Sounds like your setting is on the border, it needs a bit more of gap.
« Reply #119 on: February 16, 2018, 03:04:47 PM »
I will continue to trouble shoot things once I get my table back up and running. My G540 board crashed and I’m working on getting that fixed. Thanks for all the help
