Hello Guest it is April 25, 2024, 09:30:09 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 36411 times)
Offline TPS
  •  2,505 2,505
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #100 on: February 15, 2018, 01:57:06 PM »
GCode is ok
the box with ideas is empty now.
« Reply #101 on: February 15, 2018, 01:57:48 PM »
thats where im at........
Offline TPS
  •  2,505 2,505
« Reply #102 on: February 15, 2018, 02:10:29 PM »
may i ask you to post your Profile XML
C:\Mach3\your profilename.xml
maybe i can find something there, but i think it will be tomorrow,
it late here in Bavaria  ;).
i think we are Close.
« Reply #103 on: February 15, 2018, 02:19:15 PM »
Yes at lunch right now will post when I return.
I think we are close too. I have full function during g code, it’s just seems like it’s forgetting where my zero is for that work piece in reference to the Z AXIS. It will work on the first cut perfect, sometimes the second cut perfect, but then it goes for the third cut and dives itself into the material. I have adjusted the thc min and max as well. It seems to work in those perameterss until it decides to dive itself.
Offline Davek0974
  •  2,606 2,606
« Reply #104 on: February 15, 2018, 03:10:59 PM »
Torch dive is usually a plasma thing not a Mach thing, you are close but this can be a pain.
Is the metal flat?
Is the return lead clamped to the metal not the table?
What plasma supply do you have?
« Reply #105 on: February 15, 2018, 03:19:46 PM »
Well it’s changing it’s Z by itself in Mach. Wherever I set the Z, in reference to home, and then Zero out, run gcode, it tries to dive but I stop it before it gets to metal, then when I press return to Z, it goes all the way back To x,y 0,0 then when the Z makes it descent it tries to go lower than where I set the Z.
« Reply #106 on: February 15, 2018, 03:20:14 PM »
It seems like it’s making the Z lower than what i set it to..
« Reply #107 on: February 15, 2018, 03:21:35 PM »
But yes metal is flat. 10 ga MS cold rolled, lead clamped to table but that’s how I’ve always run it for the last 4.5 years.. I have thermal dynamic cut master a60. Been running it for years with no issues of plasma dive until now
« Reply #108 on: February 15, 2018, 03:29:23 PM »
It’s setting my Z height at zero -.7 units from where I set it before running the Gcode.
Offline Davek0974
  •  2,606 2,606
« Reply #109 on: February 15, 2018, 03:51:01 PM »
Is your Z losing steps?
