BOB88
How do you turn on the Soft Limits in Practical Lathe vs 2.0?
>>>>>> I did not put a Soft Limits button on the screen since I am aways changing the setup for different work.
If you want one, just add a button called Soft Limits, a good place would be under the Diangostics button on the main page.
Open screen designer, for regular Mach3 Mill, and see what the OEM code is for toggling Softlimts (add the LED that goes with it).
to your Practicle lathe screen.
Also, What is the space shuttle accessory and what does it do? Replace the MPG?
>>>>>>>>>>> No space shuttle accessory, I was just being sarcastic since I put so much crap on the thing.
BUT!!!!!!! If you hit the "Tab" Key, it WILL bring out a MPG shuttle window...
Your Lathe screen is indeed User Friendly and Practical. Thank you.
>>>>>>>>>>>> Thanks,
scott
