after spending o couple of hour's to get a file open/save Dialog working on win7 64bit,
i post the code here in case somebody else is searching for the same Problem
Dim Filename As String
Dim Dialog1
Set Dialog1 = CreateObject("MSComDlg.CommonDialog")
Dialog1.MaxFileSize = 256
Dialog1.Filter = "GCode Files (*.tap)|*.tap"
Dialog1.FilterIndex = 1
Dialog1.DialogTitle = "select GCode file"
Dialog1.InitDir = "C:\Mach3\GCode"
Dialog1.FileName = ""
save = false
If save = true Then
Dialog1.DefaultExt = def
Dialog1.Flags = &H800 + &H4
discard = Dialog1.ShowSave()
Else
Dialog1.Flags = &H1000 + &H4 + &H800
discard = Dialog1.ShowOpen()
End If
FileName = Dialog1.FileName
change the variable "save", to get either a open or save Dialog
if the code causes a error run this code
'Make the MSComDlg.CommonDialog class available for use. Required for filedialog function.
function registerComDlg
Set objRegistry = GetObject("winmgmts:\\.\root\default:StdRegProv")
objRegistry.CreateKey &H80000001, "Software\CLASSES\Licenses\4D553650-6ABE-11cf-8ADB-00AA00C00905"
objRegistry.SetStringValue &H80000001, "Software\CLASSES\Licenses\4D553650-6ABE-11cf-8ADB-00AA00C00905", "", "gfjmrfkfifkmkfffrlmmgmhmnlulkmfmqkqj"
end function
in vb scripter window once to registrate MSComDlg.CommonDialog on your System
Thomas
