Hello Guest it is April 27, 2024, 01:02:07 AM
Author Topic: Mach3 Error when running G-code  (Read 8367 times)
Re: Mach3 Error when running G-code
« Reply #10 on: February 06, 2018, 05:44:57 PM »
It comes up here as 6.08 and -6.08 as the extents.
Not a Mach3/4 problem as far as I can see.
Mike
« Reply #11 on: February 06, 2018, 07:08:41 PM »
How do I check scaling
How do I check steps per unit
Position your machine at X0
Then MDI G50 G1 X6 F30
Measure how far the axis moved.
The G50 will cancel any scaling that may be in effect.
« Reply #12 on: February 07, 2018, 10:53:36 AM »
Your g-code shows a diameter of about 12” so the problem is with Mach 3 settings not V-carve.
Offline Gordo
  •  17 17
« Reply #13 on: February 07, 2018, 07:47:20 PM »
I hate to be a pain but I have tried all that I know about CNC put to no avail. It seems that everything is have the size it should be, even when trying to cut threw a .76 in board and the setting is .78 in it only cuts down to .36 in not sure where to go from hear.
Thanks for you help.
« Reply #14 on: February 07, 2018, 08:05:10 PM »
Lets start with the basics. Use an one inch indicator and command a motion of one inch. See if the physical  motion matches the commanded movement.
Mike
Offline TPS
  •  2,505 2,505
« Reply #15 on: February 08, 2018, 01:24:34 AM »
done ?
result ?
Offline Gordo
  •  17 17
« Reply #16 on: February 08, 2018, 03:02:17 AM »
I will try this tomorrow. Here is a screen shot from Mach3 showing a Dia of about 14.5 "
Offline Gordo
  •  17 17
« Reply #17 on: February 08, 2018, 07:11:31 PM »
I tried setting x) and then G50 G1 X6 F30 as you can see in the pic. the movement was 6.00
« Reply #18 on: February 08, 2018, 07:39:31 PM »
MEASURE the actual axis movement with a RULER or DIAL INDICATOR.
Put a pencil mark on your table, position the spindle directly over that mark.
ZERO the DRO at that point.
MDI G0 X6.
Take your tape measure, or yard stick and measure how far the axis actually moved.....
Offline Gordo
  •  17 17
« Reply #19 on: February 08, 2018, 08:11:56 PM »
I did this and it moved about 9 1/4 inches.
