Hello Guest it is March 29, 2024, 04:44:04 AM
Author Topic: 3d scanning with mach3  (Read 5901 times)
Re: 3d scanning with mach3
« Reply #10 on: January 19, 2018, 10:59:02 AM »
Tony,
Can’t help you with the probing, I am just familiar with Keyance having used their stuff in the past.
Their laser displacment sensors are so fast they can measure a tuning fork position while vibrating at 20 Khz! So if you get this to work scanning should be really quick compared to moving the Z up and down constantly.
Offline comet
  •  336 336
« Reply #11 on: January 19, 2018, 12:44:08 PM »
OK,
    So can anyone answer the questions on the software i posted further back in the thread?
Tony
Offline comet
  •  336 336
« Reply #12 on: January 20, 2018, 01:15:04 AM »
|I have just started some basic experiments , I have set the probe input and added a hot key (p)
when i check in diog the p key works the digitize led so that seems ok.
  I am "air cutting" to test the software off machine.
  However when I run the wizard code or just run a g31 pressing the p key has no effect?
I have tried it with emulated on and off
Any Ideas??
Tony Horton
« Last Edit: January 20, 2018, 01:27:06 AM by comet »
« Reply #13 on: January 20, 2018, 02:00:38 AM »
Hi Tony,
I think you need to have the driver running in Mach for that to work.
Russ.
Offline comet
  •  336 336
« Reply #14 on: January 20, 2018, 03:54:48 AM »
Hi Russ,
   thanks for the reply, do you mean the motor drives?
Also, if I enter a feedrate of say 300 mmpm when the code is posted it says F300 but only feeds at roughly 20% of that?
and behaves the same what ever feed rate I put in 20%
Regards
  Tony
« Reply #15 on: January 20, 2018, 08:34:33 AM »
Good morning Tony.
I meant Mach will not do some things if running in simulation mode without the port driver loaded.
You can losd it from the Mach3 folder.
Give it a try.
Offline comet
  •  336 336
« Reply #16 on: January 20, 2018, 12:54:40 PM »
Hi Russ,
    No that didnt work.
Im at a looss with it all.
Tony
« Reply #17 on: January 20, 2018, 02:11:34 PM »
Tony Horton
Are you simulating ....
On your machine PC set to offline mode ?
Or on a separate pc/laptop ?
« Reply #18 on: January 20, 2018, 02:50:28 PM »
I knew I remembered this from somewhere ......
http://www.machsupport.com/forum/index.php/topic,13995.0.html
I also vaguely recall that the driver is disabled when run in "Off Line" mode .... but not certain about that one.
Good luck Tony,
Russ
Offline comet
  •  336 336
« Reply #19 on: January 24, 2018, 11:29:26 AM »
Got it all going now , software was straight forward and the system for what it cost produces excellent results.
