Mach3 Version R3.043.062
60"x120" routing table with ESS control
Picture of problem attached
We normally do not route this small, however, it does happen from time to time. I have not seen this issue on larger objects. The W on the top left is not clean at all. Changing the cut from conventional to climb gives a mirrored result. Thinking this could have been due to play in the X axis, I tore down the machine and tightened both gears. The W on the top left was then run, with no noticeable change. Both were run with Motion Mode set to Constant Velocity. I then ran the one on the bottom with Motion Mode set to Exact Stop. It came out clean. Exact Stop is just not feasible to do on our everyday jobs as they can go well over 5 million lines of G-code. I can switch back and forth if needed but I was hoping there might be a setting I missed somewhere.
