Hello Guest it is April 25, 2024, 09:46:23 AM
Author Topic: Setting the jogging speed in Mach3 - can you help?  (Read 2843 times)
« on: January 14, 2018, 11:37:48 AM »
Hi, I'm just setting up my plasma cutter table.
It would be very helpful to be able to change the jogging speed of the torch so I can slow it right down sometimes. (With the torch firing I could cut off the thin waste pieces 'manually' - that is, without having to generate a bit of code.)
I presume this is done all the time but I'm new to Mach and I haven't found a way to set the speed.
Please can you help?
Tim
Re: Setting the jogging speed in Mach3 - can you help?
« Reply #1 on: January 15, 2018, 07:31:40 AM »
Hi Tim,
I you hit the tab key a flyout will appear and then you can adjust the jog percentage in the jog DRO IIRC.
Mike
« Reply #2 on: January 15, 2018, 01:28:36 PM »
Thanks, Mike. I don't know how I missed it!
« Reply #3 on: January 15, 2018, 04:22:17 PM »
Glad I could help.
It took me awhile to find it the first time I used Mach 3.
Mike
