Hi, I'm just setting up my plasma cutter table.
It would be very helpful to be able to change the jogging speed of the torch so I can slow it right down sometimes. (With the torch firing I could cut off the thin waste pieces 'manually' - that is, without having to generate a bit of code.)
I presume this is done all the time but I'm new to Mach and I haven't found a way to set the speed.
Please can you help?
Tim
