Hello Guest it is March 28, 2024, 07:36:52 AM
Author Topic: RhinoCAM Lathe Post Processor  (Read 1129 times)
« on: January 10, 2018, 01:15:59 AM »
I read a tutorial on Pokeys lathe threading and it said Mach 4 uses Fanuc OT for GCode. Just wanted to check if that's the post processor I should use if I'm using RhinoCAM.
I usually use the built in wizards in Mach for lathe projects and have only had one project that I designed in VisualCAM. That's when I was making Steadycam gimbals and they were complex. I'm so not used to using that program and haven't done so in like a decade. So I thought I'd check out the Lathe function of RhinoCAM as I use Rhino for everything.
