Hello Guest it is April 19, 2024, 08:31:13 PM
Author Topic: Rotational Axis Radius for feed rate  (Read 1243 times)
« on: January 09, 2018, 04:45:56 PM »
I’m trying to set up Mach4 hobby where “A” axis is rotational. It will be paired with “Y” for a plasma head. For the feed rate to be correct (in”/min) I think Mach has to use the radius for calculations. I can set up a DRO for the radius but then what do I do with it? I cant seen to find any reference to set up. Any help would be appreciated.
Tony
