Hello Guest it is April 24, 2024, 12:09:46 AM
Author Topic: G-Rex 4th axis rotation limit HELP  (Read 2753 times)
« on: January 07, 2018, 04:01:44 AM »
Hi All I need help.
I have Mach3 v3-042-020 and G-Rex  with the latest plugin running 4 stepper motors. Has been running sweet  for about 10 years but I just discovered my rotary table wont turn past 2790 degrees, once it gets to 2700 it starts counting down but table still rotates in the same direction ?
Updated to Mach3Version3.043.066 hoping it may fix the problem but no luck.
I can get the unlimited rotation  if I run without G-Rex, so I suspect its an issue with Grex not mach3. Spent a good 6 hours trying different settings to no avail.
Has anyone had any luck with rotation beyond 3000deg, I need to get to 7920deg. (22 full turns).
I have attached my xml
« Last Edit: January 07, 2018, 04:05:43 AM by sven_d »
