Hello Guest it is April 25, 2024, 06:21:19 AM
Author Topic: Code stops at line 488  (Read 1670 times)
« on: January 06, 2018, 09:25:20 PM »
I'm ramping down to a depth on a slot and the code repeats x and y after line 488. I checked the flash drive I'm using and the code is all there. Also tried a different flash drive and the same result. Also tried reprogrammed only one of the three slots and also the same thing.
Sent from my XT1650 using Tapatalk
  •  9,199 9,199
Re: Code stops at line 488
« Reply #1 on: January 07, 2018, 01:36:32 AM »
If you are using Mach3 in Demo mode then it is limited to ~500 lines of code.
The Mach3 license removes this limitation; http://www.machsupport.com/shop/mach3/
« Reply #2 on: January 07, 2018, 04:48:29 AM »
You should also not run from the flash drive but copy the file over to the hard drive.
Mike
