Hello Guest it is April 19, 2024, 12:10:46 PM
Author Topic: Wells_Index 823 CNC Milling Machine - Girard Ohio 44420 - $700  (Read 5140 times)
Need to make some room so putting this machine up for sale:
Wells Index 823/847 CNC Milling Machine
9x46 inch Table
#30 NMTB - Erickson #30 Quick Change Spindle
Reuland 2hp 3phase Motor Variable Speed Head
Windows XP PC with Mach3 CNC Software
Server Case containing CNC4PC Breakout Board + Axis Drives + Power Supplies
Superior Electric Slo-Syn Stepping Motors
Machine runs good ive made a lot of stuff on it
Needs a few things buttoned up - Limit Switch set needs brackets made and mounted etc.
Ballscrews in Nice shape could be used manually if handles attached
and has extended X screw for standard power feed attachment
Head only runs in High gear - wells index sells the part to fix it i just never did
Wells Index is still in business so parts are still available
Spindle Motor is 3 phase so you will need a Phase Converter or Variable Frequency Drive
VFD's can be purchased off ebay - these are inexpensive and offer a lot of options
I can load onto a car hauler type trailer for free
but must remove the head to get it out the garage door
cash preferred - possible trades
buyer must pick up no shipping In Girard, Ohio 44420  - North Side of Youngstown Ohio
Mill base with Head no Steppers or control - $700
Mill with Head + Steppers and Mounts - $900
Mill Complete with Mach3 + Steppers + Control Box with drives psu's and BOB
+ 6" Vise + #30 NMTB Jacobs Drill Chuck - 1900
Links:
http://www.wells-index.com/
http://vintagemachinery.org/mfgindex/detail.aspx?id=2280&tab=3
http://vintagemachinery.org/mfgindex/detail.aspx?id=2280&tab=4
« Last Edit: January 28, 2018, 03:07:37 PM by Chaoticone »
Re: Wells_Index 823 CNC Milling Machine - Girard Ohio 44420 - $700
« Reply #1 on: January 28, 2018, 02:38:17 PM »
mill sold please delete
thanks machsupport  :)
« Last Edit: January 28, 2018, 03:06:41 PM by Chaoticone »
