Hello Guest it is April 19, 2024, 03:23:21 PM
Author Topic: Plugin to run script on Shutdown  (Read 12117 times)
Re: Plugin to run script on Shutdown
« Reply #10 on: May 10, 2018, 12:18:02 PM »
Is the plug-in running through Windows Script Host?
I logged in as administrator, but I would like to run as a single user with limitations like a kiosk mode pc, for that I'm using SteadyState on XP.
My project is a Windows XP with a HMI flat panel, running a kind of kiosk mode, and it works perfectly well!!
The only thing I need, is to power off whole system when closing Mach3.
Just for test, running on Windows 10, works fine
Here I left the dialog asking for which user would run the vb script. I have to unchek protect my computer and data from unauthorized program activity, and hit ok to exetute the script. After that all works fine.
So, I would start to read in some vb forums.
