Hello Guest it is April 26, 2024, 05:58:49 PM
Author Topic: Problems with Jogging, (Mach3, USS)  (Read 7355 times)
« on: January 04, 2018, 02:38:24 PM »
I've faced this problem before, while 3 axis jogging. I can jog in any direction 2 axis (xy and xz and yz), but there is a problem with 3 way. I can jog NorthEast, but can't simultaneously jog the Z(3axis Jog). The system beeps when I try to do it. All other 3 sides, the 3axis jog works flawlessly. After upgrading to the latest recommended version of Mach3 and smoothstepper plugin for it (v17), the problem still exists, (I thought updating Mach and the plugin for the UsbSmoothStepper and also the USB driver for the board itself so Windows recognizes it, would fix the problem, but it didn't) That's why I came here to ask the community about it, maybe someone else had the problem. Additionally, the spindle doesn't want to manually stop using the button in Mach (mind you, Spindle is relay controlled). The only way to stop the spindle is to press Stop in Mach.
Thank you for reading and also for a possible reply.
Greetings I3Lcnc
Re: Problems with Jogging, (Mach3, USS)
« Reply #1 on: January 04, 2018, 03:04:28 PM »
Here's the xml config, if anyone will need it  :)
