Hello Guest it is March 28, 2024, 08:25:50 PM
Author Topic: need help plssssss  (Read 3834 times)
need help plssssss
« on: December 19, 2017, 02:37:51 PM »
Hello
I use this forum because I have no solution to my problem. i was building my cnc and I used a MACH 3 MOTION CARD MKX IV controller, the problem is that when I open a Gcode file in Mach 3 with the plugin for this card it is totally different from what I designed, if I disable the NcUsbPod plugin then mach3 open the file Gcodem I tried to change the format (tap, nc, ncc, gcm etc.,) the same result
Re: need help plssssss
« Reply #1 on: December 19, 2017, 02:59:26 PM »
this is the movie whith problem
https://vimeo.com/248034301
  •  9,196 9,196
« Reply #2 on: December 20, 2017, 02:43:34 AM »
Hi Andrei,
Because you are using Mach3 in Demo...
Mach3 will load the whole of your Gcode when it is not connected to a controller.
When it is connected to a controller it will only load the first 500 line of Gcode. (this is a restriction placed on the Demo)
You need to purchase a Mach3 license to unlock the software; http://www.machsupport.com/shop/mach3/
« Reply #3 on: December 20, 2017, 04:19:45 AM »
Yes thank you I tray whit a program with less line and is working, thank for lighting my life :) I will buy the program
