Hello
Guest
it is
April 26, 2024, 09:11:51 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Cutting points instead of line
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Cutting points instead of line (Read 1554 times)
Tona
1
on:
December 13, 2017, 01:43:20 PM »
Hello,
I have a plasma CNC and I'm trying to cut a simple path (a square), the problem is that the CNC is cutting points instead of a line.
I'm new using Mach3 but I think that it might be a software configuration problem because in the drawing I see the cut path as a line, the machine follows the path but instead of cutting a line it only makes points.
Link to a picture of the points.
https://imgur.com/8jbI11w
joeaverage
7,575
Re: Cutting points instead of line
Reply #1 on:
December 13, 2017, 04:27:08 PM »
it rather looks like either your plasma is not able to run continously or your machine is inertrupting the cut signal.
Can you put a voltmeter on the cut signal to determine whether its your machine or your plasma.
TOTALLYRC
861
Reply #2 on:
December 30, 2017, 03:07:37 AM »
Could you post the Gcode just to make sure that it is correct?
Mike
Print
Pages:
1
Go Up
« previous
next »
