Hello Guest it is April 20, 2024, 05:45:09 AM
Author Topic: Wrong Motor Moving  (Read 3310 times)
Wrong Motor Moving
« on: December 11, 2017, 10:52:28 PM »
Setting up new DSPMC controller with Mach4 - Latest firmware and plugins installed
X Axis assigned mMotor (0)
Y Axis Assigned Motor (2) as master, Motor(1) as slave
Z Axis assigned Motor (3)
All motors are controlled via Step/Direction
Here is what is happening. From the DSPMC Config screen,
 - select Motor(0), do a test motion for this motor. Motor(0) move as it should, but Motor(1) follows Motor(0)
 - Select Motor(2), do a motion test for this motor, Motor(2) moves, but Motor(1) does not.
 - Remove Motor 1 as Slave for Y Axis, do a motion test for Motor(2), no motion on Motor(2), Following error for Motor(1)
I have reviewed all configuration parameters and all looks OK
Any thoughts? Thanks,
Re: Wrong Motor Moving
« Reply #1 on: December 11, 2017, 11:41:22 PM »
Try this config:
Y Axis Assigned Motor (1) as master, Motor(3) as slave
Z Axis assigned Motor (2)
« Reply #2 on: December 12, 2017, 11:40:32 AM »
Change DSPMC controller with one for another machine. Downloaded configuration and functions as expected. Re- installed original controller, did a factory reset, download configuration. Same issues as before. Motors will not follow assigned axis.
« Reply #3 on: December 12, 2017, 02:34:08 PM »
please package your mach4 profile and screen and email to support.  will check it out.  thx.
