Hello Guest it is April 23, 2024, 08:28:32 AM
Author Topic: AlphaCAM, Mach3 milling post processors  (Read 43313 times)
Re: AlphaCAM, Mach3 milling post processors
« Reply #20 on: July 31, 2013, 01:38:31 AM »
Hi Graham, Henry here. I've finally received my MachMotion kit for my router. Is there a possibility that you can have another look at the code which I sent to you as I still have the problem of the code slowing right down when it gets to radii of any size. The rest of the code runs smoothly.Cheers.
« Reply #21 on: February 16, 2018, 07:38:18 AM »
Hi Graham, I'm new to the forum and just saw this post, I have tried the alpha router post for cabinet vision, seems like it would work but it ask me for a code/password which is 4 digits, any ideas? any help will be much appreciated, thanks in advance
Offline Graham Waterworth
  •  2,673 2,673
  • Yorkshire Dales, England
« Reply #22 on: February 27, 2018, 08:06:00 AM »
Hi Henry,
there is nothing in the g-code telling Mach to slow in the corners so it could be a CV setting that is causing this.
  •  2,673 2,673
« Reply #23 on: February 27, 2018, 08:08:40 AM »
Mancuza,
my advice would be stay well away from Alphacam now a days!
« Reply #24 on: October 02, 2018, 05:13:48 AM »
hello all please i need help
i have bridge saw cnc for cut the marble stone 5 axis i will retrofit ro Mach3 and i have alphacam software i need some one help me for build post processor can made it under payment
Thanks for your help.
pop
« Reply #25 on: October 27, 2020, 04:18:54 PM »
heyy
is there is a mach3 for 4 axis (A axis) to use in alphacam
  •  2,673 2,673
« Reply #26 on: October 27, 2020, 07:43:27 PM »
Use a 4 axis Fanuc one.
« Reply #27 on: October 28, 2020, 06:07:26 AM »
I don’t have it so pls can u send it to me.
