Hello
Guest
it is
March 28, 2024, 10:30:34 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach4 newbie here. I need some help
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Mach4 newbie here. I need some help (Read 8882 times)
Azalin
181
on:
November 15, 2017, 08:10:47 AM »
I just purchased Mach4 and the Darwin PP plugin for my retrofitted lathe. The lathe worked well with Mach3 so I thought it would be easier to setup Mach4 but I realized it is the opposite. Anyway, please read my questions. Any help would be appreciated.
1- In Mach3, I assigned the Enable to pin 1. I did the same on Darwin and Mach3 Mach config. In Darwin Output screen when the "Freq when active" is set to 0 then it doesn't work. Under the text field it says "For PWM enter 1/2 of the base freq. What is the base freq? The only frequency I set is the PWM base frequency for spindle and it is 300.
2- I have set the Charge pump to pin 17. In Mach3 when I hit the Reset button the Enable and Charge pump was triggering at the same time. When "Enable" is active the charge pump become active. When "Enable" id inactive the charge pump become inactive. This works fine in Mach3. In Mach4 I have no idea how to map the "enable" and "charge pump" together.
3- In Darwin Motor Config tab I enabled only 2 motors (Motor #0 for X and Motor #1 for Z). In the same screen there are 2 drop-down menus labeled "X axis" and "Y axis". For the X axis I select Axis0. Fine. But what should I do for the Z? There is no drop-down for the Z. I think this screen is developed for mill?
Logged
joeaverage
7,575
Re: Mach4 newbie here. I need some help
Reply #1 on:
November 15, 2017, 11:27:49 AM »
I suspect that you will find more answers in the Darwin Parallel Port discussion thread on this board.
There has been some discussion here lately about the charge pump in Mach4/Darwin PP and the upshot is that it doesn't work too well,
I understand that most people no longer consider it necessary and don't use it.
Logged
joeaverage
7,575
Reply #2 on:
November 15, 2017, 11:46:29 AM »
just had a thought about another question you raised.
On Configure/Mach/General page check the <X-Z> Active plane and then try assigning motors etc.
raig
Logged
Azalin
181
Reply #3 on:
November 15, 2017, 11:54:01 AM »
I did this but I think it doesn't effect the Darwin. In motor config screen in Darwin the Y drop down is menu still there.
Logged
joeaverage
7,575
Reply #4 on:
November 15, 2017, 12:36:09 PM »
Hi Azalin,
can't be of much help, I don't use Darwin but rather an ESS so I was just guessing.
Logged
Azalin
181
Reply #5 on:
November 15, 2017, 02:58:00 PM »
Thank you Craig
Logged
ger21
6,295
Reply #6 on:
November 15, 2017, 03:07:09 PM »
Charge Pump issue discussed here.
http://www.machsupport.com/forum/index.php/topic,27194.msg245834.html#msg245834
Logged
Azalin
181
Reply #7 on:
November 15, 2017, 03:10:52 PM »
Oh god. 109 pages. But thanks Gerry.
I feel hopeless. I think it's better I get an Ethernet M16 board.
Do they accept return/cancel order for the Darwin plugin?
Logged
joeaverage
7,575
Reply #8 on:
November 15, 2017, 05:50:26 PM »
Ethernet M16 board? I don't recall ever hearing of a board of that name being Mach4 capable.
ESS, PMDX various, PoKeys various, CNCDrive some,Vital Systems various, yes, but Ethernet M16 no, never.
Logged
Azalin
181
Reply #9 on:
November 15, 2017, 06:02:45 PM »
It's pokeys branded.
https://cnc4pc.com/m16-pokeys-motion-motherboard-for-mach4.html
Logged
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
