Hello Guest it is April 19, 2024, 06:07:01 AM
Author Topic: Newbie running Mach 3 Software needs help  (Read 2601 times)
« on: November 14, 2017, 12:37:43 AM »
Have built a CNC Router connected to a Desktop via Parallel port using mach 3 software running on Windows XP. Loaded Demo Gcode "Roadrunner" and everything works great, but the size of the routing is only 12mm x 12mm. What have I done wrong in the Setup.
Re: Newbie running Mach 3 Software needs help
« Reply #1 on: November 14, 2017, 02:36:47 AM »
I'm guessing that your machine is interpreting the Gcode as mm units when the RoadRunner (being a Yankee!) is in inches.
Try on the MDI screen coding G20 <enter> and run the code again. G20/G21 are used to allow the Gcode interpreter to use either inches or mm's as units.
« Reply #2 on: November 14, 2017, 05:38:14 AM »
Thanks for the information, I will try this tomorrow morning
