Hello Guest it is October 11, 2026, 03:44:39 PM
Author Topic: problem with probe action  (Read 6816 times)
« on: November 07, 2017, 05:59:29 PM »
I am a new installer of Mach 4 on a router table, my progress stopped at the touch module function.
When I click on the find Z tool surface Z moves down and the probe trips and nothing else happens. >:(
The probe indicator shows when the probe make contact and not when it is not in contact so that is correct.
I expect the Z to retract and set the Z DRO to 0.0 this does not happen. :o
I am running a PMDX-416 USB board and that is the only plug in I have enabled and Mach 4 is build 3284
Hope there is help from someone here.
Re: problem with probe action
« Reply #1 on: November 08, 2017, 09:39:11 AM »
Ok my problem seems for be fixed I received a reply from Tech Support for a change to the "Probe feed rate" and a change to the Lua file from Mike Abbott.
 https://www.pmdx.com/PMDX-Forums/index.php?topic=356.0
 Also I was using a wire touch for the testing the probe test and I found I was to fast with the touch.  If I held the contact for a short time longer is would work correctly.
Many thanks to Bryanna for quick replies to my questions.
