Hello
Guest
it is
April 23, 2024, 06:48:13 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Stop CV on Angles?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Stop CV on Angles? (Read 1811 times)
rrc1962
673
Stop CV on Angles?
on:
October 30, 2017, 04:19:19 PM »
Does Mach4 have anything similar to Stop CV On Angles like Mach3 had?
Logged
Chaoticone
5,624
Precision Chaos
Re: Stop CV on Angles?
Reply #1 on:
October 30, 2017, 11:03:16 PM »
Well, you can set the feed rate for any angle from 0 - 179 degrees. So, setting the speed for angles above 90 degrees to 0 would work.
The mcCVTuning wizard can populate the table for you giving the same result.
But, the mcCVTuningWizardV3 wizard in this topic is far better. It's smart enough to set the feed rate for angles to maintain a tolerance you enter in the wizard.
http://www.machsupport.com/forum/index.php/topic,35860.msg245507.html#msg245507
Last Edit: October 30, 2017, 11:05:59 PM by Chaoticone
Logged
If you could see the things I have in my head, you would be laughing too.
rrc1962
673
Reply #2 on:
October 31, 2017, 09:06:06 PM »
Your CVTuningWizard is awesome. That should do the trick. Thanks.
Logged
Chaoticone
5,624
Precision Chaos
Reply #3 on:
November 01, 2017, 09:01:49 AM »
No problem
Logged
Print
Pages:
1
Go Up
« previous
next »
