Hello Guest it is April 16, 2024, 01:46:14 PM
Author Topic: Screen for shuttlepro2 with axis LEDS and incriment display  (Read 2790 times)
« on: October 25, 2017, 05:05:18 PM »
I would like to known if there is a screen set available that will display the axis selection with a screen LED in the DRO like on the Tormach when using the shuttlepro2. Also looking a section on the screen that will display the current incremental step wirhout calling up the "TAB pendant".
I have found that the selected axis tends to run away when the incremental movement is selected on the "TAB pendant" and the shuttlepro2 knob is moved. I would just assume to turn off jogging with the keyboard all together to avoid this issue.
Thanks in advance,
Ben
