Hello Guest it is April 26, 2024, 06:09:20 AM
Author Topic: Remove BKSPACE from Hotkeys  (Read 4203 times)
« on: October 20, 2017, 11:32:40 AM »
Hello, i have a few questions about some hotkeys and some minor stuff that may be silly, but for me it isn't:
1) Given the title, we're so used to press BKSPACE to erase some wrong typed characters that i do that so often
and my emergency goes on. Is there a way to remove this shortcut to ESTOP from the BKSPACE ?
2) If there is a way, can we also erase characters we type like... in MDI ?
3) Also my resolution is 1080p(Monitor), MACH3 window seens just so weird and small, is there a way to make it better?
I think for now, this is more urgent.
Re: Remove BKSPACE from Hotkeys
« Reply #1 on: October 20, 2017, 01:36:45 PM »
Hi
What screenset are you using?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: October 20, 2017, 02:14:24 PM »
The default screenset.
« Reply #3 on: October 20, 2017, 02:32:36 PM »
As far as I know uses the screenset 1024.set ESC for reset. Did you change any hotkey settings?
Klaus
« Reply #4 on: October 20, 2017, 04:25:41 PM »
About your screen size issue. Did you try Mach3's config menu -> General Config "Auto Screen Enlarge"? Don't forget to reload the screen after changing Mach3's window size.
Klaus
« Reply #5 on: October 20, 2017, 04:37:31 PM »
Auto Screen Enlarge does do much...
No i didn't change anything.
« Reply #6 on: October 20, 2017, 04:52:48 PM »
you could send me your screenset and profile and I'll have a look at it
My Email: klaus.dietz@kd-dietz.de
Klaus
« Reply #7 on: October 20, 2017, 07:13:22 PM »
Okay, i'll email you.
« Reply #8 on: October 21, 2017, 03:57:34 AM »
About your issue "BS resetting Mach3".
To turn off BS resetting Mach3 do the following:
start Mach3 with your profile VRNIKA
use menu Config -> Ports and Pins -> Input Signals
scroll down to EStop
click the Hotkey field in the EStop line
click top right button X to close window. This will remove the BS value
About your resolution issue
the screenset 1024.set has a display ratio of 4 : 3. If you are using a monitor with a ratio of 16 : 9 Mach3 stretches the dimensions to fill the screen. This will result in a loss of X and Y relation. If want to keep the ratio you can use MachScreen V1.68
use menu Options -> Resize Page
click Select All
select User defined of Page Size
specify Pixel hor and Pixel Vert
click OK
save the screen
Klaus
« Reply #9 on: October 21, 2017, 11:34:41 AM »
Nicely done Klaus, nicely done. Thanks a lot.
