Hi!
So, I'm doing a project involving a Mach3 powered CNC with a custom fixture. In essence, we are not doing any tooling, but merely using the CNC head to travel in a regular path while it carries a probe that's performing some surface treatments.
Thanks to an electrical malfunction (without going into too much detail, my experiment involves high voltages which backfired thanks to a miswiring), I've lost all my code (and the USB key that it was backed up on).
Since my background is in a field completely unrelated to engineering (chemistry), I have literally zero experience using gcode.
My experiment basically involves moving the head in repeatable straight lines for N times at a set feed rate. Could anyone help me whip up some basics, at least for the loop function?
Through trial and error and what I remember from my protocol/ cobbled together from what I found online, this is similar what I'm doing. Unfortunately I also forgot the initialisation parameters
M3
G1 X0 Y0
G1 X15 F0.5
G1 Y0.5 F0.5
G1 X0 F0.5
G1 Y1 F0.5
G1 X15 F0.5
M30
My old version of the code looked something like this, repeating until Y=15. My experiment basically involves changing the step size (Y0.5 to ex Y0.3 or whatever) at a set feedrate.
I know it's asking for a lot, but it would really save my rear, especially as this is the only gcode that I'm likely to ever need in my life.
Thanks in advance!
