When I hit either the -X limit or the -Y limit Mach 4 faults and I get an error, that's all well and good. But when I clear the history and try to reset the fault it just continues to fault out. It's not allowing me to go into jog and back it off. If I do the same thing in the +x or +Y direction I'm able to reset then go into jog and back it off the switch. Any suggestions? I'm running it with a Warp9 ESS.
