Hello
Guest
it is
April 25, 2024, 03:52:53 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
Proximity Limit Switches
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Proximity Limit Switches (Read 3488 times)
Chaz
48
on:
October 16, 2017, 03:42:44 AM »
Ive had a look through the 57U manual. Is it possible to connect up either PNP or NPN proximity switches as limits / homing?
If the 57U cannot do this, can the CNC board?
Logged
Chaz
48
Re: Proximity Limit Switches
Reply #1 on:
October 16, 2017, 12:15:29 PM »
NeoTo?
Logged
NeoTO
504
Reply #2 on:
October 18, 2017, 03:40:12 PM »
Note that this is not the official support channel from PoLabs - if you have a question, contact us by opening a ticket on the support page!
Regarding your question - see the manual Mach4 and PoKeys57CNC - step by step guide.pdf (2.55 Mb) (
https://www.poscope.com/wp-content/uploads/downloads/Pokeys/LibrariesAndPlugins/Mach4%20and%20PoKeys57CNC%20-%20step%20by%20step%20guide.pdf
). It contains the description on how to wire proximity switches to PoKeys devices.
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Chaz
48
Reply #3 on:
October 18, 2017, 03:59:33 PM »
Yes, understood. However I needed to answer stuff like software version etc that I didnt have on me. Plus, here, others can benefit from the answer.
Logged
Chaz
48
Reply #4 on:
October 18, 2017, 04:03:16 PM »
Plus, the response is for 57CNC and Mach4. What about 57U?
Logged
NeoTO
504
Reply #5 on:
October 19, 2017, 11:45:53 PM »
The manual I listed contains also general information and exactly the information you are requesting - see pages 14 and 15.
The only difference is that PoKeys57U has weak pull-up resistors to 3.3V and you can add external 10k pull-ups to +5V if the sensor requires.
Logged
www.poscope.com
Print
Pages:
1
Go Up
« previous
next »
