Hello Guest it is April 19, 2024, 01:54:39 AM
Author Topic: Custom LED with a unused code ???  (Read 2918 times)
« on: October 12, 2017, 11:08:37 AM »
I want to add a few LED's to an existing screen. I will have a brain drive the LED's. However the function of the LED is not a standard OEM type, I want it to be custom. My brain has output to OEMLED: 1001 etc.
How do I create a custom LED on an existing Mach3 screen that will turned on/off via my brain using for example OEMLED: 1000, 1001 etc???
Using MachScreen, when I select an LED, It seems like I can only select from the provided list of standard LED's that already exist on the mach3 screens.
« Last Edit: October 12, 2017, 11:10:33 AM by slow-poke »
Re: Custom LED with a unused code ???
« Reply #1 on: October 12, 2017, 02:02:56 PM »
if you are using MachScreen as your screendesigner, select the LED and enter your ID in the OEM-Code line of the property dialog.
Klaus
The brain isn't a soap, it doesn't shrink when used.
