Hi Daryl,
Rustins code should be close to working.
First go to Operator/Edit Screen and <Go To Work Zero>. Open the Left Up script:
GoToWorkZero()
--local inst = mc.mcGetInstance()
--mc.mcCntlMdiExecute(inst, "G00 G53 Z0\nG00 X0 Y0 A0\nG00 Z0")
Note that the two lines of code are commented out, they do nothing. They have been put there so you can see and interpret what function GoToWorkZero() does.
The actual working code is in the screen load script.
Open the Screen Load script and scan down until you find the function you want, in my script line 218:
mc.mcCntlMdiExecute(inst, "G00 X0 Y0 A0")--Without Z moves
--mc.mcCntlMdiExecute(inst, "G00 G53 Z0\nG00 X0 Y0 A0\nG00 Z0")--With Z moves
end
Rustin used the second line of code by uncommenting it but I'm dubious about the G53 code, that means that coord system for this move is in machine cords.
May I suggest trying:
mc.mcCntlMdiExecute(inst, "G00 X0 Y0 ")
which by my reckoning will move at rapid traverse speed to X0 Y0 of work co-ords with no Z axis movement.
Evidently Rustin tried a similar edit and generated an error, I don't know why. One thing which occurred to me was 'what would happen if work co-ords are not defined
yet', would that cause an error that Rustin described?
It seems to work on my laptop...both with and without work co-ords being defined.
As I suggested in an earlier post if you find that this wee mod works save the modded screen set with a distinct name. Then use the new improved screen set in
your profile. That should prevent your favoured screen set being overwritten with an update.
