January 22, 2018, 06:55:58 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| | |-+  Help with control box industrial power switch?
Pages: 1   Go Down
Print
Author Topic: Help with control box industrial power switch?  (Read 331 times)
Durero
Active Member
Offline Offline
View Profile
« on: September 13, 2017, 02:32:58 PM »
My rotary power switch is jammed!
I can not fully rotate it to the off position or to the on position.
Does anyone know where I could find an installation guide for this type of switch?
I've disassembled the internal (inside the control box) part of the switch and it is perfectly fine.
The spring mechanism in the outside part of the switch seems to be jammed.
Any advice would be greatly appreciated!
I've attached a picture of the switch.
Durero
Active Member
Offline Offline
View Profile
« Reply #1 on: September 13, 2017, 10:55:20 PM »
Found a helpful document here http://www.automation-dfw.com/pdf_elec/baco03-disconnectswitches.pdf
 and was able to fix the switch.
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.20 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
