Hello Guest it is March 28, 2024, 04:24:50 PM
Author Topic: Mach4 modbus plugin problems  (Read 2876 times)
« on: September 11, 2017, 01:07:34 PM »
I'm having an issue with the Mach4 Modbus plugin. When I go to set up a new modbus serial connection, it is not giving me any options for the serial port. The "port" dropdown is completely blank. I know there are two serial ports in the computer as they show up in the Serial plugin config. I tried it on a different computer and the ports show up correctly. I am using version 3481.
Anyone gave any thoughts?
Keith
Re: Mach4 modbus plugin problems
« Reply #1 on: September 13, 2017, 03:59:42 AM »
Hi Keith,
haven't had any problem here with an earlier build.
I'm trying to replicate what your are doing:
1) Configure/Plugins/Modbus
2) Click Add NEW Modbus Connection icon top left
3) Name, Description and Type <Next>
4) Enter Serial Com properties, check 485 <Next>
5) Confirm <Finish> or <Cancel>
I have these three screenshots of 3),4),5)    Do they match what you see?
« Reply #2 on: September 13, 2017, 07:07:35 AM »
Thanks for your help. I can get as far as the second screen shot but that is where the Port menu is not populated. I have attached a screen shot. I thought at first that for some reason the plugin did not like the built in serial ports on the computer so I tried an external USB serial port with the same result. The computer itself does detect the serial ports as I can use them using Teraterm. The "Serial" plugin in Mach4 also sees them as well. It is just the Modbus plugin that is having the issue.
« Reply #3 on: September 15, 2017, 08:12:44 AM »
Just as an update I have found and fixed the problem. In my windows 7 setup there were several services that were turned off, one of which was causing the problem. I'm not sure which one was the issue but when I set them all back to the default state the problem went away.
« Reply #4 on: October 28, 2018, 08:13:55 PM »
Hi Guys,
ive made a very easy setup tutorial for the MACH4 MODBUS and Spindle Control
watch the full post and tutorial here:
http://www.machsupport.com/forum/index.php/topic,38560.new.html#new
regards cncprint.blogspot  Grin
« Reply #5 on: November 12, 2018, 11:59:06 PM »
The link above does to an error article not found page.  Please re-link.
Thank you,
Cyprian
« Reply #6 on: November 13, 2018, 12:25:54 AM »
Try this:
http://forum.machsupport.com/forum/index.php/topic,38560.new.html#new
URL changed because the forum is running on a temporary new address due
to web site updates.
Steve Stallings
www.PMDX.com
