Hello at all,
I try to set a new machine but I can´t connect to CSMIO Controller. The Device is not found.
I set the IP Adress of the network controller to 10.1.1.1 and subnetmask to 255.255.255.0 as the manual is telling.
The Computer (Windows 10) is connected to the controller with the needed crossover cable.
When I start the machine the LED on the crossovercalbe is flickering as normal, trying to get connection. After a while it just stays on, no more flickering.
At the command box after entering arp /a to show all connected devices I just found a static adress 10.1.1.255 but not the needed dynamic 10.1.1.2 of the machine.
It´s like the machine is not connected. Of course I also can´t ping the machine.
I tried 2 different cables and computers. Did somebody have the same problem or can help me? I need a solution. This ist the 4th machine we set, but never had such problems.
