Hello
Guest
it is
April 26, 2024, 03:37:40 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
movement on curve manually in oxy cutting machine by Mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: movement on curve manually in oxy cutting machine by Mach3 (Read 1591 times)
rahnama
2
on:
August 21, 2017, 06:52:52 AM »
hi all
I am using mach3 first time and made a oxy cutting machine.
it work normally but I want to move on the curve (which designed and converted to G code) manually before run cutting.
who can help me how to do this.
I can move on X & Y axis bot not on the curve.
thanks
Logged
garyhlucas
660
Re: movement on curve manually in oxy cutting machine by Mach3
Reply #1 on:
August 21, 2017, 08:50:34 AM »
If you are talking about jogging manually it is not possible to jog along a curve as the X and Y feed rates are changing continuously. Even if the machine could do it, you would need an analog joystick with two axis to do that.
Logged
joeaverage
7,575
Reply #2 on:
August 21, 2017, 02:39:12 PM »
you could issue MDI codes but you'll have to work out the Gcode manually.
Logged
rahnama
2
Reply #3 on:
August 25, 2017, 11:27:18 PM »
thanks alot
Logged
joeaverage
7,575
Reply #4 on:
August 26, 2017, 12:09:23 AM »
have you experimented with G3 and G3? I've found that the centre format command style to be useful assuming you know where the centre of the
arc is supposed to be.
Logged
Print
Pages:
1
Go Up
« previous
next »
