Hello Guest it is April 18, 2024, 01:01:55 AM
Author Topic: Intermittent inaccuracy  (Read 5563 times)
« on: August 15, 2017, 10:01:07 AM »
I noticed my X axis was inaccurate. Went to Settings and re-calibrated X axis. Tested a few times and each time it was spot on. Ran a file that I had cut previously and the X was out again? The problem is intermittent, sometimes accurate, sometimes not. The problem appears to be during the Jog cycle, when the steppers make a sudden noise and stutter. Today I was trying to cut a 2mm deep pocket after cutting about 80% the Z axis started cutting down to almost 6mm. I'm on a steep learning curve so any help or suggestions will be greatly appreciated
  •  9,197 9,197
Re: Intermittent inaccuracy
« Reply #1 on: August 15, 2017, 11:13:31 AM »
That sounds like you have one or more stepper motors stalling.
Try reducing your Velocity and Acceleration settings by 50% in Motor Tuning (save the changes for each axis) and see if this cures the problem. If it does then experiment to find the fastest, reliable speeds that suit your machine.
« Reply #2 on: August 28, 2017, 05:33:29 AM »
Hi Tweakie
Thanks for your guidance and sorry for the late response, I have been on leave. I reduced the V & A and so far so good. Perhaps you could help with another issue. The Z axis runs out while cutting a file. 99% of the time it maintains the correct depth, but every so often it gradually cuts deeper, especially when pocketing. Can you help?
Many thanks
Dougie
  •  9,197 9,197
« Reply #3 on: August 28, 2017, 05:43:15 AM »
Hi Dougie,
Two possibilities come to mind...
1) Tool slipping / not tight in collet or loose coupling / grub screw, etc. driving the Z axis.
2) Loosing steps when Z axis is raising against gravity - check for mechanical tightness / binding (and that the axis is lubricated correctly) also try reducing the V and A in Motor Tuning.
Is your Z axis stepper motor getting 'hot to the touch' in use ?
« Reply #4 on: January 24, 2018, 01:20:47 PM »
My Z axis has a gas spring counterbalance because it is heavy and ball screws back drive so well that it comes right down if I hit E-stop or loose power.  This also means the stepper motor doesn't have to overcome the weight of the Z and the load of cutting, so it never misses steps.
