I noticed my X axis was inaccurate. Went to Settings and re-calibrated X axis. Tested a few times and each time it was spot on. Ran a file that I had cut previously and the X was out again? The problem is intermittent, sometimes accurate, sometimes not. The problem appears to be during the Jog cycle, when the steppers make a sudden noise and stutter. Today I was trying to cut a 2mm deep pocket after cutting about 80% the Z axis started cutting down to almost 6mm. I'm on a steep learning curve so any help or suggestions will be greatly appreciated
