Hello Guest it is April 24, 2024, 06:33:33 PM
Author Topic: Tool Zero Code w/ Wait for Probe Confirmation  (Read 4464 times)
Re: Tool Zero Code w/ Wait for Probe Confirmation
« Reply #10 on: August 15, 2017, 07:17:27 PM »
As you are doing I always touch the touch plate to the probe before running the routine to verify that I have a complete circuit.  My touch plate is a 1" thick piece of aluminum and my probe speed is 5 IPM.  When probing my hand is always on the e-stop, just in case.  The aluminum and low feedrate is somewhat forgiving should you have an over run situation.
Tom
« Reply #11 on: August 15, 2017, 07:53:03 PM »
But my main screen does not have a probe status LED indicator. I'm not sure if it has it but I did purchase a copy of the 2010 screen set a while ago but had some initial problems running it so I saved that project for a rainy day that hasn't come yet.
« Reply #12 on: August 15, 2017, 08:50:21 PM »
It's pretty simple to add one.
« Reply #13 on: August 15, 2017, 10:31:29 PM »
OK, I'll look into that too!
