Yesterday I was doing some motor tuning (changing microstepping on X and Y) and got this error code, -1.#IND showing in the X and Y axis DRO when I turned off microstepping. Could not get the code to clear even after I reset the dip switches to their original configuration. I uninstalled Mach (if it means anything ver 062) and reloaded and all is well now. What does this code mean? I always understood that you could run Mach without microstepping so I'm unsure what happened.
