Hello Guest it is April 16, 2024, 02:02:27 AM
Author Topic: Was the problem ever fixed where Local Var inputs cause Mach3 to hang?  (Read 4026 times)
From what I have read in the forum, as far back as 2008 it was reported that using a local variable as an input to a brain would cause Mach3 to hang.  Was this problem ever resolved? I am using Demo Version R3.043.066 for my code development and it exhibits the problem.
Thanks.
-Jim
Re: Was the problem ever fixed where Local Var inputs cause Mach3 to hang?
« Reply #1 on: September 01, 2017, 03:53:37 PM »
I could not get a COMPARE block to compare a digital/boolean switch to activate even though I could see the switch input toggle between 1/0 in the Brian viewer.....
     so I set up to inputs , one was the switch input 1/0 and the other as a variable=1  and then tried to compare those two (after a no-operation pass thru)  and yes, my mach3 hung up...and may bot even allow my PC to open that profile without crashing...it think i may have to remove the offending Brain from the folder.....stand by.....
« Reply #2 on: December 20, 2018, 12:47:27 PM »
I'm not sure...... I switched my machine to UCCNC, as it had the "electronic gearing" spindle encoding capability I needed for threading.
 I may some day take the old controller that I was using with MACH3 and use it on some other machine.
