Hello Guest it is March 28, 2024, 05:39:30 AM
Author Topic: Slow blow or fast blow?  (Read 3718 times)
« on: July 31, 2017, 10:09:07 PM »
I'm looking for a consensus on whether I should use slow blow or fast blow fuses on my system. I fully understand that slow blows are used to protect components that can withstand a temporary inrush of of higher current, but that still doesn't tell me whether my components should be exposed to that inrush. I'm using the Long's Motors kit as follows:
36volt power supply
5 volts borrowed from the PC PS to power the DB25-1205 B.O.B.
Three 3 amp motors
DM542A drivers
Thanks for any help.
  •  9,196 9,196
Re: Slow blow or fast blow?
« Reply #1 on: August 02, 2017, 01:42:25 AM »
There is differing opinions regarding exactly which parts of an installation should be fused as in some instances rapid voltage disconnection (blown fuse) may cause just as much damage as not having a fuse at all.
My advice would be just to fit slow blow fuses on each of the mains inputs to devices (PSU, Spindle, etc.).
« Reply #2 on: August 02, 2017, 09:49:42 AM »
