Hello Guest it is April 18, 2024, 10:19:29 PM
Author Topic: Triple edge zero finding plate problems  (Read 5645 times)
  •  9,198 9,198
Re: Triple edge zero finding plate problems
« Reply #10 on: August 03, 2017, 02:33:54 AM »
Hi Ian,
Your .xml file is in your Mach3 folder and it is called    Mach3Mill.xml
On the attached image I have marked pin 13. Is this the pin you are using ?
By changing the Mach3 Probe configuration (different pin) do any of the other inputs (pins 10,11,12) work ?
« Reply #11 on: August 03, 2017, 06:41:20 AM »
Yes that is the pin I am using Pin 13.
All the other pins are in use. Pins 10,11 and 12 are connected to my limit switches for x axis, y axis, and z axis and all work fine.
I am struggling with the .xml file, but i've sent it directly to your website again.
Ian
  •  9,198 9,198
« Reply #12 on: August 03, 2017, 07:27:28 AM »
I think we have now covered all the possibilities and my conclusion is (as you suspected) the breakout board Pin 13 is bad.
Limit switches do not need separate inputs (except for slaved axes) so they can share just one Input pin. This could free up a working Input for use with your Probe. Alternately, a new (perhaps better quality) breakout board is required ?
« Reply #13 on: August 04, 2017, 04:34:32 AM »
Thanks once again for your reply.
I think we have both come to the same conclusion- time for a new board replacement.!!!
Can't thank you enough.
ian
  •  9,198 9,198
« Reply #14 on: August 04, 2017, 05:29:57 AM »
Hi Ian,
Thank you for your kind words.
« Reply #15 on: August 14, 2017, 06:47:23 AM »
Hi Tweakie,
Well one week on and i'm pleased to report that I have replaced the board with a more recent model and all is working fine.
As you will remember the problem arose when I found the script from Allen Massey to use a triple edge finder. Well that is working fine too after much head scratching altering the script from imperial measurements to millimetres to suit my machine.
You offer a great service, much appreciated.
Ian
  •  9,198 9,198
« Reply #16 on: August 14, 2017, 06:59:11 AM »
Hi Ian,
I am pleased to hear that all is now working well and congrats on converting that script from Imperial to Metric  ;)
