Hello Guest it is March 29, 2024, 05:36:22 AM
Author Topic: stepper motor dro says 2 inch but actual distance traveled was 3 inch how to cac  (Read 1407 times)
Offline gorf23
  •  183 183
 if the stepper motor dro says 2 inch but actual distance traveled was 3 inch  is the a formula
how to caculate new steps as per real distance traveled.. Sorry but my math isn't top notch..
Thanks gary
2/3 times your steps unit.
Offline gorf23
  •  183 183
so if I am understanding this correct it should be like
DistanceTravled  = 3  Steps unit = 1800
 DroDistance  = 2
x = DistanceTravled * Steps unit
new steps unit = DroDistance  / x
Thanks gary
Offline mark4
  •  167 167
hi there are a few ways to do this. the best and most accurate is the way in the manual complete calculation ie ball screw pulleys motor ect then check with a Gage block or dial indicator. you could just plug in a different number up or down until 1" on dro = 1" traveled this isnt the most accurate but depending upon what machine you are running i am sure it has been done that way before.
mark
