Hello Guest it is October 02, 2026, 08:40:17 PM
Author Topic: Setting WCS with Haimer 3D  (Read 10132 times)
« on: July 22, 2017, 09:59:20 AM »
This is probably a simple question to answer for the experienced, but I rarely get to use Mach4 to learn the ins and outs of everything so I'm at a loss for the moment.
What I've done is set up my Haimer 3D sensor as my tool 1--the height is set in the table to when the Z length is zero'ed out. My other tools are also setup in my Mach tool table.
I load my g-code I wish to run, insert the Haimer on the machine manually, and then on the Program Run screen enter the current tool as 1. I zero out the X and Y edges of the part and lastly the top of the stock. At this point I remove the sensor, press cycle start and insert the first tool during the tool change pause. Cycle start again and then the program runs. The Z comes down and then begins operation at a height a few inches about the part. (It's at Z zero for the Haimer, but say the flycutter being shorter is not at the correct lower height)
In the past I just set the first tool touching off of the part but now having the Haimer I'd like to be using that for setup.
Re: Setting WCS with Haimer 3D
« Reply #1 on: July 22, 2017, 11:39:18 AM »
In most CNCs I have run the T word must have another code to apply tool length like H1. So you need to apply the length for the Haimer before setting 0 then apply the length for the new tool.
« Reply #2 on: July 22, 2017, 02:37:46 PM »
See the Gcode manuals that come with the install of Mach4 (Docs folder). They cover tool offsets.
« Reply #3 on: July 25, 2017, 09:44:43 AM »
Looks like I figured out my problem, I didn't have the Active Tool Height turned on while setting the zero. Again, a simple mistake from my lack of using the software.
« Reply #4 on: July 25, 2017, 03:26:40 PM »
Glad you got it sorted.  :)
« Reply #5 on: July 30, 2017, 12:27:14 AM »
This sounds very much like the issue I had in my post the other day. I'll have a look for the Active Tool Height and see if that fixes my problem.
